Author Topic: Nested Marker Bug  (Read 2579 times)
Nested Marker Bug
« on: August 09, 2023, 09:59:43 pm »
Simple scene.
Nested L1S  and A2S Generators via Selector just for quick change and troubleshooting.
Master Generator is as usual named "Master".
Null Transform on the corners to get sections.
Nested X Size via Macro to get Adjusted sections.
Parameters connected to Macros to override inputs if Marker Data has some value.
Something is wrong. The whole generator is acting weird when changing the Height Marker Data and  Evenly Data is not affected at all (the Data[0] affecting the Data[1]).
The Style seems okay, it is working fine when changing constant parameters.
Just go on RC Spline and tweak those two.
« Last Edit: August 10, 2023, 06:37:28 am by Dragan »
Re: Nested Marker Bug
« Reply #1 on: August 10, 2023, 08:38:43 am »
Hi Dragan,
In the provided scene, both macros use the same User Data value (#0). Once the one changed correspondingly (to #1 for the X Evenly Distance), it seems to work just fine. I'm attaching the modified scene (230810_Marker Bug_iToo.max).
« Reply #2 on: August 10, 2023, 09:01:01 am »
 :o :o :o
 ;D ;D ;D ;D
Sorry!
It was 4.00 am
I forgot how to use my own Macros!!!!!
Thank You!
Once again, sorry for the false alert!   ::) ::) :-[ :-[
« Reply #3 on: August 10, 2023, 09:14:30 am »
No worries at all. I'm glad that’s working fine. ;)
