Author Topic: Help me choose the method of making the stadium  (Read 4202 times)
Tarpan
« on: September 18, 2017, 03:25:55 pm »
Help me choose the method of making the stadium. The problem is that the top of the stadium has a curved surface and a straight surface. The upper and lower element should not be deformed, only the middle part is deformed. The method I chose suits completely, but there are non-joining parts. Scene attached, please help.)
« Last Edit: September 18, 2017, 03:28:21 pm by Tarpan »
Re: Help me choose the method of making the stadium
« Reply #1 on: September 20, 2017, 11:47:20 am »
Because of the different heights of Segment in the "middle" part and whole array rotation by the X Rotation value, this rotation should be maintained also by the "bottom" part Generator to maintain the alignment. Attaching a modified scene.
If needed, by using Y & Z Offset of involved Generators, these can be readjusted as needed (like in the second attached version).
Hope you'll find it helpful.
Tarpan
« Reply #2 on: September 20, 2017, 12:13:01 pm »
Thank you so much! We need more such lessons !!! )))
harumscarum
    • harumscarum's portfolio
« Reply #3 on: September 30, 2017, 01:32:58 pm »
wow. how is it possible to make style editor transparent?
« Reply #4 on: October 02, 2017, 11:15:15 am »
I'm afraid that's not possible to adjust the opacity of the Style Editor window (I've superposed two screen-shots in a graphic editor).
Best regadrs,
