RailClone => RailClone Pro (*) => Topic started by: Tarpan on September 18, 2017, 03:25:55 pm
Title: Help me choose the method of making the stadium
Post by: Tarpan on September 18, 2017, 03:25:55 pm
Help me choose the method of making the stadium. The problem is that the top of the stadium has a curved surface and a straight surface. The upper and lower element should not be deformed, only the middle part is deformed. The method I chose suits completely, but there are non-joining parts. Scene attached, please help.)
Title: Re: Help me choose the method of making the stadium
Post by: Michal Karmazín on September 20, 2017, 11:47:20 am
Because of the different heights of Segment in the "middle" part and whole array rotation by the X Rotation value, this rotation should be maintained also by the "bottom" part Generator to maintain the alignment. Attaching a modified scene.
If needed, by using Y & Z Offset of involved Generators, these can be readjusted as needed (like in the second attached version).
Hope you'll find it helpful.
Post by: Tarpan on September 20, 2017, 12:13:01 pm
Thank you so much! We need more such lessons !!! )))
Post by: harumscarum on September 30, 2017, 01:32:58 pm
wow. how is it possible to make style editor transparent?
Post by: Michal Karmazín on October 02, 2017, 11:15:15 am
I'm afraid that's not possible to adjust the opacity of the Style Editor window (I've superposed two screen-shots in a graphic editor).
Best regadrs,
