Author Topic: Help needed with window blinds script  (Read 5214 times)
Uwe Kreuzahler
  • 3D Visualization Director
    • 3D.CR
« on: November 01, 2019, 06:51:44 pm »
Hello
I need to create a animation for window blinds and I'm having a issue and need some help
As you can see on the screenshot 10_degrees.jpg I'm using numeric input fields to control the animation, but when i move the blinds to a value of 50 degrees i get additional blinds to cover the height value (see screenshot 50_degrees.jpg}
How can i set the amount of blinds used as a static value? Obviously the distance between the blinds and the amount of blinds should be always the same.
I tried to attach the max file to this post, but got a Intrernal server error 500 after i submit, so instead i uploaded the file to our server
Anyone who can help me to solve this problem?
thanks
Uwe
http://3d.cr/outside/RC_blinds_001.zip
« Last Edit: November 01, 2019, 06:57:36 pm by Uwe Kreuzahler »
Photorealistic Architectural Visualizations
www.3D.cr
Re: Help needed with window blinds script
« Reply #1 on: November 01, 2019, 07:39:21 pm »
I can't open your file since I`m still on Max2015 but try to:
1. Export X Fixed Size on your Transform node
2. Connect Blinds_Distance
3. On Transform General >> Check `Fixed Size` and UNCHECK `Scale Segment`
Uwe Kreuzahler
    • 3D.CR
« Reply #2 on: November 01, 2019, 07:59:23 pm »
Hi Dragan
thanks for the feedback
I tried your changes, but it didnt work
I did convert the max file to max15
You can download it here http://3d.cr/outside/RC_blinds_001_max15.zip
Can you open it?
www.3D.cr
« Reply #3 on: November 01, 2019, 08:16:56 pm »
Yes, I can and I see you are using 2 RC objects. Whit RC4 you can do everything in ONE RC object.
How do you want your Generator to behave? I mean which parameters you want to have/drive?
Uwe Kreuzahler
    • 3D.CR
« Reply #4 on: November 01, 2019, 08:23:46 pm »
Oh I didnt know that about using only one RC Object
The goal is to use the numeric inputs: Blinds height, Blinds Distance and Blind Rotation to animate the blind
the distance between the blinds needs to be the same, so no additional blinds will be inserted when i start rotation - currently it fills up the height with additional objects
The final goal should be that i add the RC to a spline - as done in the RC_Blinds_window
I hope i made myself clear and didnt add confusion to this post :-)
www.3D.cr
« Reply #5 on: November 01, 2019, 09:02:37 pm »
« Last Edit: November 01, 2019, 09:28:24 pm by Dragan »
Uwe Kreuzahler
    • 3D.CR
« Reply #6 on: November 01, 2019, 09:33:24 pm »
works like a charme
Thanks a lot :-)
Wish you a great weekend!
www.3D.cr
« Reply #7 on: November 01, 2019, 09:35:26 pm »
Great.
Just re-download from the EDITED link. I restrict/recalculate some parameters.
Best Regards
Uwe Kreuzahler
    • 3D.CR
« Reply #8 on: November 02, 2019, 01:44:17 am »
Hi Dragan
thanks again for your excellent help
Much appreciated
best
Uwe
www.3D.cr
« Reply #9 on: November 02, 2019, 06:30:37 pm »
Glad to help.  ;)
