Toggle navigation
Login
Register
RailClone
RailClone Pro (*)
Help on creating random sized cobblestone road, following a spline path.
« previous
next »
Print
Pages: [
1
Author
Topic: Help on creating random sized cobblestone road, following a spline path. (Read 10773 times)
KQ4371
Newbie
on:
July 10, 2024, 12:38:23 pm »
Hi there.
I'm stranded, with a problem i cant wrap my head around in Railclone.
i want to create a road of different sized stones (see Attached Excample01.png).
The stones have to follow a spline ( green spline on Example04.png)
my Railclone setup is as seen on Attached Example02.png.
My problem is that i get the result you can see on Attached Example03.png - i can´t se to get it right.
can someone help me?
Best regards
Michael
Last Edit: July 10, 2024, 12:50:38 pm by KQ4371
Logged
Administrator
Hero Member
Re: Help on creating random sized cobblestone road, following a spline path.
Reply #1 on:
July 10, 2024, 01:30:55 pm »
Please take a look to the attached sample.
I used a parameter to define the size of array on Y, and same value divided by 2 to apply a negative Y offset.
Logged
KQ4371
Newbie
Reply #2 on:
July 10, 2024, 02:40:08 pm »
hi there.
Thanks for the reply!!, its close, but I'm trying to get the random cobblestones to line up 90 degrees to the X-spline.
Best Regards
Michael
Logged
ITOOSOFT
Hero Member
Reply #3 on:
July 11, 2024, 12:26:36 pm »
Hello Michael,
Thanks for clarifying. Please see the attached file which uses an L1S generator nested inside another L1S generator to create that effect.
Please let me know if you have any questions,
Logged
KQ4371
Newbie
Reply #4 on:
July 12, 2024, 10:43:19 am »
Thank you so much!! for the reply, that was the solution to my problem!.
Thanks!
Best regards!
Logged
Print
Pages: [
1
« previous
next »
RailClone
RailClone Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
