Author Topic: help with a pavement lines.  (Read 5117 times)
CgRod
« on: August 30, 2015, 07:56:49 pm »
Hi I have a little problem, I need these lines are as shown in the drawing, I have 2 figures.
-a line of square pavement (box1) going in the corners
-box 2 is between box1
prepare a RailClone, Box 1 as the start, end and corners.
box 2 evenly, but not achieving the result.
this doing something wrong. also try secuence but I got no result, much overlap.
It is one of my first attempts with railclone and I think it would be easier
I hope your answers
greetings thank you
Re: help with a pavement lines.
« Reply #1 on: August 31, 2015, 10:36:21 am »
I would suggest you to check our "Getting Started with RailClone" on-line guide, specially the "8 - Create your first 1D array" part you might find very useful.
A style using the "box1" as a Start Segment, than the Sequence connected to the Default slot and "box2" as the End Segment should do the job.
Please feel free to attach the .max file containing that style, so we can take a closer look at it. Or if you'd prefer, send it to support@itoosoft.com. In case of big file size, please use a web sharing service as WeTransfer.
