RailClone => RailClone Pro (*) => Topic started by: DN1876 on February 19, 2023, 05:47:56 pm
I am trying to create a claustra wall like the attached image with a A2S array.
I am not familiar with the node the graph need to mirror the geometry every second raw.
Could someone please help me with the sequence of the parts or pointing me to a similar tutorial?
I have also attached a file with the geometry.
https://we.tl/t-UXLMcWitAM
Thanks in advance!
There are several possible ways how to set it up – in my opinion, using multiple Sequence Operators (in both Increment at X and Increment at Y modes) should be a good option. Please find attached the modified scene (220221_itoo_support_help_iToo.max).
Hi Michael, thank you for time and effort.
it looks fine, I will try to better understand the graph and replace the square at the joint to an hexagon so it looks more solid as a wall.
Have a great day!
