Author Topic: Interpolation between two splines  (Read 2435 times)
BT4215
« on: February 14, 2023, 10:44:24 am »
I'm building this bridge but I'm stuck with the struts connected to the arch structure.
How is possible to distribute the tie rods to the arc and scaling/rotating them properly?
Best regards.
Re: Interpolation between two splines
« Reply #1 on: February 14, 2023, 05:05:08 pm »
Thanks for the interesting question.
I'm afraid at the moment there's not an easy way to achieve this, RailClone doesn't (yet) have a generator that can create geometry between two parallel splines. However there are a few workarounds that might be possible. Please take a look at this thread for a similar case.
Cheers!
« Reply #2 on: February 14, 2023, 05:16:48 pm »
I've made a simplified scene that may be of help. It's a pretty simple setup but it might help in this case. Any questions, please let me know.
BT4215
« Reply #3 on: February 20, 2023, 11:18:57 am »
Thank you very much.
I hope to see more modules/operators in RailClone Pro.
For example I use also Grasshopper and I think that many geometries can be modeled directly within 3ds Max.
Best regards.
