Author Topic: Road junctions  (Read 3082 times)
EM4616
Road junctions
« on: January 23, 2023, 10:31:02 am »
Is there a way in which I can create a road intersection at the intersection of two Splines, so that I can also connect the intersection segment and the road segment in a good way?
attach a file,
Thanks !
arch3d
    • arch3d.pl
Re: Road junctions
« Reply #1 on: January 23, 2023, 11:41:50 am »
EM4616
Re: Road junctions
« Reply #2 on: January 23, 2023, 11:50:25 am »
Thanks a lot, though
Still can't find a specific solution for what I was looking for
arch3d
    • arch3d.pl
Re: Road junctions
« Reply #3 on: January 23, 2023, 12:53:56 pm »
You can separate verical and horizontal roads. Use 1st generator as clipping area.
Sory i did it in rush but you should get an idea. You need to synchronize pivots to get proper result.And placemet of markers has to to be very accurate. Both splines should have same interpolation. A lot of circumstances for consideration
« Last Edit: January 23, 2023, 01:22:00 pm by arch3d »
