Author Topic: Help with weird slicing of geometry  (Read 5600 times)
Anthony - Inca CGI
« on: August 16, 2015, 04:40:04 pm »
I've just bought Railclone today and I'm slowly getting into how it works.
I have made a curved wall with some mosaic tiles and when I render there is some weird clipping occurring which doesn't show up in the viewport.
Converting to Editable Poly fixes the issue but this isn't ideal as I would like it to remain editable inside Railclone.
Pictures attached, any help would be greatly appreciated. I have literally tried every setting.
Anthony
Re: Help with weird slicing of geometry
« Reply #1 on: August 16, 2015, 05:02:31 pm »
That's a strange issue. Would you mind sharing the source file so I can take a closer look and diagnose the problem? If you'd prefer not to post it here please feel free to send it to us at support@itoosoft.com and I'll look at it ASAP.
Many thanks,
Anthony - Inca CGI
« Reply #2 on: August 16, 2015, 05:03:29 pm »
Turning off the 'Use Instancing Engine' seems to get rid of the issue (see attachment.)
Is this a bug maybe? I'd like to keep this on as the project I am currently working on has something like 200,000 tiles required and I will struggle memory wise if the proxy/instancing system is unavailable.
Anthony
Edit - I have just emailed the scene to you - thanks
« Last Edit: August 16, 2015, 05:12:12 pm by Anthony - Inca CGI »
« Reply #3 on: August 16, 2015, 05:12:38 pm »
Use instancing engine is somewhat similar to collapsing the object to a mesh so it will render exactly as in the viewports. It may be a bug but we haven't encountered it before.  I'll check out the source file and hopefully I'll  be able to give a you a better idea of what the issue is and if it is a bug, we'll look at how to fix it. Otherwise I might be able to suggest a workaround.
Many thanks,
« Last Edit: August 16, 2015, 05:14:40 pm by Paul Roberts »
« Reply #4 on: August 17, 2015, 10:34:32 am »
Hi Anthony,
I have answered via email too with an amended file.  Thanks for reporting this issue, we've been able to identify a bug that occurs when using a Y Spline in conjunction with the X-Rotate property. However there is a workaround that maintains instancing you can use instead. Remove the existing Y Spline and use the Generator's Y Size property instead. You can then rotate the array into the correct position using the X Rotate property set to 90 degrees and you should find it renders correctly.
Many thanks,​​​​
« Last Edit: August 17, 2015, 12:57:19 pm by Paul Roberts »
Anthony - Inca CGI
« Reply #5 on: August 17, 2015, 06:01:02 pm »
Excellent,
Thanks for your help. I have actually started to turn off the instancing engine as loading the proxied versions of my railclone objects seems to take a lot longer than non-proxies. I'm guessing it's down to writing out the proxies and then reading them back in once the render is started?
Cheers
Ant
