Author Topic: Irregular stone wall style...almost there need help with style!  (Read 4383 times)
Terri Brown
    • Terri Brown 3D
Hi guys,
I am busy creating an irregular stone wall in RC. So far, all is fine (see test render attached), except for the top pieces and how they connect with the last default segments at the top.
Alignment is automatic for all top pieces. I have added top padding to the default segments of -110mm to make them connect well together. There's no top padding on top segments.
What am I missing? Do you need any other info?
Please help!
Thanks a mil,
Terri
Re: Irregular stone wall style...almost there need help with style!
« Reply #1 on: May 03, 2018, 08:41:15 am »
Great style !
For this kind of styles, most important parameters are:
No Slice for default segments- so they can lock with Top Part.
And calculated  Array 2S Y size.
That is basically it.
If that does not help, please send us your scene
Terri Brown
    • Terri Brown 3D
« Reply #2 on: May 03, 2018, 10:06:17 am »
Thanks Rokas. No Slice worked a charm, but when I set the wall to 9700mm (it's real height), it's now too high. If I set it any lower, only the top segment moves down, and default segments don't adjust. I have sent you my file.
