Author Topic: Path Deform (WSM)  (Read 3489 times)
JM2915
Path Deform (WSM)
« on: December 09, 2015, 04:33:20 pm »
I have a problem animating a spline using the "Path Deform (WSM)".
If  I animate the modifier, the railclone objects do not update between frames (or even in the viewport, when moving the timeslider).
Is there any solution to this?
Jan
Re: Path Deform (WSM)
« Reply #1 on: December 10, 2015, 11:55:08 am »
Hi Jan,
Thanks for getting in touch about this issue. WSMs are handled differently in max from normal modifiers and it seems that this is a tricky bug that we'll need to investigate further. At the moment the only solution I can think of is to use the standard Path Deform modifier or possibly a Skin modifier depending on what you're trying to achieve.
JM2915
« Reply #2 on: December 10, 2015, 04:18:14 pm »
I never ever got the "normal" path deform modifier to work in a predictable way, so this is out.
I am trying to do a train animation.
Currently I am using the "Start" parameter on the spline to animate the train, but I want to use multiple railclone objects.
So to synchronize I tried to wire the parameters, but this does not seem to work either.
Or is there a solution to this.
Seems like I will have to duplicate the animation by hand...probably faster than trying to find a solution.
« Reply #3 on: December 10, 2015, 08:38:25 pm »
You can wire RailClone's parameters but they're not automatically visible to in wiring menus. To make them show up, just add a keyframe to the track you'd like to wire and it will become available.
I've attached a sample file with 2 RailClone objects with wired Spline > Start values (plus a slider).
Thanks!
