Author Topic: Railclone2 Material ID issue  (Read 74927 times)
IT1371
« on: May 24, 2013, 05:43:49 pm »
I'm messing around with Array 2S for a while and I noticed that you can't set up material IDs for your segments.
Whenever you create a segment, convert it to Poly and then apply an ID for it (for example - 1), Railclone mixs up everything and might display the segment as Material ID 5,4,3 and 6.
Help! ???
p.s
using 3ds max design 2011
« Last Edit: May 24, 2013, 05:47:15 pm by Panibor »
Re: Railclone2 Material ID issue
« Reply #1 on: May 25, 2013, 10:18:11 am »
Please, send us a test scene. I'm testing Array 2S here, but i cannot reproduce the problem.
