Author Topic: how to align a Sidewalk  (Read 3166 times)
QK1362
« on: May 02, 2017, 11:53:55 am »
to the surface without bending on the Borders?
thanks
Re: how to align a Sidewalk
« Reply #1 on: May 02, 2017, 12:54:48 pm »
As mentioned in this thread: "To work correctly the RailClone object should be entirely enclosed by the boundaries of the surface. If the RailClone object overlaps a boundary, unwanted deformation can occur. Feel free to scale down your Clipping Spline a bit to double check, if it helps with those artefacts."
QK1362
« Reply #2 on: May 02, 2017, 01:51:23 pm »
thanks for your quick answer but it doesnt help me :(
 i've done the steps you told me too but it didnt work out ...
i created an Railclone object with auto-grid adjust the slicing settings and inset the spline about 6cm
« Reply #3 on: May 02, 2017, 03:29:25 pm »
Thanks for the provided scene. Usually, it's better to have the Surface "oversized" a little bit more. In the attached scene, where I've used the Outline (& Inset) value of 50 cm (I've exaggerated it to show, that's in this case better to have enough space around the Clipping area) it behaves correctly. Attaching the modified scene. Hope you'll find it useful.
Best regadrs,
QK1362
« Reply #4 on: May 02, 2017, 04:56:20 pm »
ok thanks so i have to instantiate the railclone object after creating a clean border or untick "renderable" in the object properties to hide the construction plane for the final render.
thanks!
