Author Topic: Railclone macro can`t save Parameters order.  (Read 13569 times)
Joker1979
« on: September 18, 2024, 09:26:50 am »
I have this problem. I create my macro, I name everything correctly, I organize it, I save it, I refresh, I upload it and I have the same thing again. Is this a Railclone bug? Raiclone Pro 6.1.7.
« Last Edit: September 18, 2024, 10:22:33 am by Joker1979 »
Re: Railclone macro can`t save Parameters order.
« Reply #1 on: September 18, 2024, 11:04:47 am »
That’s quite unusual. The issue seems to be with the inputOrder parameter: in your file, the value 5 is duplicated across several parameters. However, once reordered and saved, it appears correct. Could you please try restarting 3ds Max and see if the issue persists? I’ve attached the resaved .rcm file for you to check whether it loads correctly on your end.
Thank you in advance for any additional details you can provide about this issue.
Joker1979
« Reply #2 on: September 18, 2024, 12:48:22 pm »
Thanks, everything works, I've already checked and found the path to the folder "C:\Users\admin\Documents\Itoo Software\Railclone Pro\Macros\Building" and overwrote it there and it worked.
