RailClone => RailClone Pro (*) => Topic started by: Macker on November 20, 2019, 10:41:05 am
Hey all,
I'm trying to create some parametric columns that replicate the one's I've made in sketchup. Basically the middle timber section will be to scale/tile depending on the length of the column, and then capped off at either end with the metal pieces; I think this is something I could achieve myself fairly easily... But how do I get the bases that the columns sit on (and the parts where they meet the roof) to stay upright on the Z axis?
I hope this makes sense?
Don't worry, solved it!
Here's the max file for anyone that wants to use it.
I was just about to post a sample file that is basically identical :)
Glad you found a solution and thanks for sharing it with the community.
All the best,
