Author Topic: how to distribute an object a long a path with increasing distance? please help  (Read 2722 times)
PT
hi,
i am a newbie in Railclone and have actually an easy problem. i couldnt get the result after trying 1 hour :(
how to distribute an object a long a path with increasing distance (between the objects)?
please help. Thank you in Advance
best regards
peter
Hi Peter,
You might find interesting this related thread. One of the possible ways would be to define the X Size of an empty Segment (linked to the Sequence Operator) by the Arithmetic Operator – in a similar way you may drive the Left / Right Padding value(s). In case of using two Parameters (like Start Distance, End Distance as in the attached sample scene), the expression should be following: return Input1 - (XsectionPosition*Input2);
In latest versions, please feel free to use the bundled macro “Increment by X Position”.
PT
Hi Michal,
Thank you so much for your Help and this so fast.
i will study the file and the link
best regards
peter
