RailClone => RailClone Pro (*) => Topic started by: PT on March 13, 2020, 12:23:15 pm
hi,
i am a newbie in Railclone and have actually an easy problem. i couldnt get the result after trying 1 hour :(
how to distribute an object a long a path with increasing distance (between the objects)?
please help. Thank you in Advance
best regards
peter
Hi Peter,
You might find interesting this related thread (https://forum.itoosoft.com/railclone-pro-(*)/change-scale-and-distance-over-spline/). One of the possible ways would be to define the X Size of an empty Segment (linked to the Sequence Operator) by the Arithmetic Operator – in a similar way you may drive the Left / Right Padding value(s). In case of using two Parameters (like Start Distance, End Distance as in the attached sample scene), the expression should be following: return Input1 - (XsectionPosition*Input2);
In latest versions, please feel free to use the bundled macro “Increment by X Position”.
Hi Michal,
Thank you so much for your Help and this so fast.
i will study the file and the link
best regards
peter
