Author Topic: How to keep segments aligned vetically ?  (Read 38022 times)
theedge
« on: July 25, 2013, 04:18:23 pm »
Here is an image of my problem :
Those wood beams are placed with railclone. The segments have exactly the same shape of course, but simply different heights to accomodate the various levels of the building.
Each story has its own spline to accomodate for different window positions.
As you can see, I cannot get the beams to line up vertically from level to level. Is there a way to achieve that ?
Thank you.
Re: How to keep segments aligned vetically ?
« Reply #1 on: July 25, 2013, 09:02:19 pm »
It seems the window's width is not an exact multiple of the separation between panels, so that is causing the alignment difference. I would try increasing the padding or the window (left or right), until getting an exact value.
If that doesn't work, please send us a test scene. I'll take a look to it.
