Author Topic: How to make a Library Featherboard Panel Style 'step' on an incline ?  (Read 8701 times)
3dvisuals.co.uk
I wish to use the pre-installed fence panel styles which come within Railclone Pro, the one I'd like to use is Featherboard Panels 1.8m.
My garden has a slope so when I use a spline the fencing follows the spline line and I end up with a fence which looks fake for my project (the fencing top follows the line of the slope).
I wish the panels to always be horizontal and only 'step' up to the top of the slope in increments of the panel width (i.e. 1.8 metres).
What do I need to change (I've taken a look in the Style Editor but cannot see it.
Thanks.
Re: How to make a Library Featherboard Panel Style 'step' on an incline ?
« Reply #1 on: September 22, 2015, 09:08:01 am »
Thanks for contacting us. To fix that style you will need to change the deformation mode of the panels from Vertical to Stepped.
This will remove the deformation and the panel will be positioned at the height of the spline at the start of the path section. Optionally you could enter a small value for Vertical Bottom so that the gravel board continues to follow the spline while the top remains stepped.
In the existing style the top of the boards continues over the posts so you will need to prevent that by adding and empty segment to the Start,End, Corner, and Evenly inputs of the second generator and enter a Fixed X-Size value of 100 mm to match the size of the posts. You should also set this segment to stepped.
Please find an amended version of the fence style attached with these changes.
Many thanks,
