Author Topic: there is a weird Bend at the end of the handrail. Please help me.  (Read 9441 times)
cc8boy
    • C7design
I am still struggling make the U-turn Stair. I managed to make the whole stair. But there are some Weird
Bends at the end of the handrail. See my file and my picture. I can’t figure it out a whole day. Please help me. Thanks.
Re: there is a weird Bend at the end of the handrail. Please help me.
« Reply #1 on: June 29, 2014, 02:40:03 pm »
Thanks for contacting us. I just had a look at your scene, setting the "Head" segment's Left Padding to a value less than -7 seems to fix this issue without affecting the rest of the style.
Hope that helps,
cc8boy
    • C7design
« Reply #2 on: June 29, 2014, 03:09:02 pm »
I can't imagine changing the padding setting of the end segment will affect the bend of whole line. My path spline is perfectly straight without any segments.  I wonder why there is a weird bend with my setting. Thanks.
« Reply #3 on: June 29, 2014, 03:25:32 pm »
I'll look into why it is behaving this way in more detail with Carlos but it looks as though it is to do with the order of evaluation. If you turn off the mirror node you can see that the handrail's position changes to the higher level you're seeing in the file you sent me.
This also explains why the Padding fixes the issue, because the handrails position then ignores the size of the end cap.
« Reply #4 on: June 29, 2014, 07:06:02 pm »
It may be a bug, probably caused by a numerical approximation error at the spline's end.
I've added the problem to the to-do list.
« Last Edit: June 30, 2014, 08:39:15 am by iToo »
« Reply #5 on: June 30, 2014, 01:38:25 pm »
This problem is already fixed for the next update.
