RailClone => RailClone Pro (*) => Topic started by: lukx on February 23, 2021, 10:11:48 pm
Title: how to make everything fit together in this chainlink fence
Post by: lukx on February 23, 2021, 10:11:48 pm
I'm tryin to create this kind of chain link fence I made all the parts but having problems how to make it all fit nicely together. I would like to avoid using transform as it's hard to fit it perfectly.
Title: Re: how to make everything fit together in this chainlink fence
Post by: lukx on February 24, 2021, 10:58:51 am
I made few modeling mistakes this one works better but still bottom and left part is mismatched in Raiclone.
Post by: lukx on February 24, 2021, 11:31:27 am
this is the best could do but still gaps and things are moved
Post by: Paul Roberts on February 24, 2021, 11:48:37 am
As far as I can see there are still some issues with the source models. They don't quite jigsaw together and align correctly and the bottom as you can see in the image.
(https://i.imgur.com/pMCBh8y.png)
I've played with the geometry a little to get it to work, but it might need a tidy up! Aside from I've made a couple of other changes as follows:
- Move the pivots for the frame to the Inside on the X and Y axis and updated pivot settings. Now Top/Bottom uses Y pivot, Start/End uses Z Pivot, and Corners use X and Y Pivot. All segments use Z pivot. This will save on having to resize one generator to fit inside/outside another.
- Sliced the wire segments slightly differently to make them easier to line up on the X axis.
- Changed/removed several padding and translation settings.
- Shared same X/Y spline between both generators
I hope it helps, please let me know if you have any questions.
Post by: lukx on February 24, 2021, 12:18:52 pm
Thank you Paul. I fixed the geometry (it nicely matches everything when copied into frame) Just not sure how to adjuts RC to fix chain links top, bottom, sides with the frame.
Post by: Paul Roberts on February 24, 2021, 12:57:36 pm
Please check out the attached file. Note again that I have sliced the geometry slightly differently from you. For X axis RailClone's adaptive mode takes care of things. Unfortunately there is no Y Adaptive mode so I've made a macro to create a similar effect. This is my old geometry I'm afraid, but hopefully it helps.
Post by: lukx on February 24, 2021, 12:58:36 pm
once again I cut objects as you did and now it's almost good just tiny slide here at the top and bottom.
Post by: Paul Roberts on February 24, 2021, 01:20:53 pm
You should be able to fix that by adjusting a few padding values here and there. Here's a revised version of that file. I've added the vertical adaptive mode to it as well.
Post by: lukx on February 24, 2021, 01:46:03 pm
Fantastic, works awesome. Please don't hesitate to add it to fences library in future RC versions if you want, at least I can do :)
Post by: Paul Roberts on February 24, 2021, 02:52:49 pm
Glad we could help out, and thanks for the offer :)
