Author Topic: Method to check MatID change within a Spline  (Read 5784 times)
suppenhuhn
« on: September 27, 2017, 11:24:20 am »
in my RC-Object ( Array 2S ) i got 2 Variations : Window with opening Wings ( assigned to MatID 1 ) and a fixed Frame (  assigned to MatID 2 ). Both are using Inner-Corner Elements.
Works fine as long there is a seperate spline for each MatID  ( attached Screenshot: upper / middle Spline )
But often i need to combine those 2 variations in one spline ( Screenshot: lower Spline ) so i have to check on Vertex V2 if it's a inner corner or not. Because in this case i need:
  • a different Right-Slide / Top-Right-Corner / Bottom-Right-Corner for the Object on MatID 1
  • a different Left-Slide / Top-Left-Corner / Bottom-Left-Corner for the Object on MatID 2
I'm sure this could be fixed with Expressions and/or Conditions ... but to be honest i have no glue which Expressions are needed :-/ Or is there a Tutorial which covers this "requirement" ?
Would be thankful for every hint:)
« Last Edit: September 27, 2017, 11:52:23 am by suppenhuhn »
Re: Method to check MatID change within a Spline
« Reply #1 on: September 27, 2017, 03:20:45 pm »
As mentioned here: "... to handle this kind of situations, there are two attributes: XSplineMatID & XSplineNextMatID. The XSplineMatID for Corners returns ID of segment BEFORE the corner and the XSplineNextMatID, which in case of Corners returns ID of segment AFTER the corner."
Hope that helps.
suppenhuhn
« Reply #2 on: September 28, 2017, 10:30:18 am »
Awesome - thank you! :-)
