Author Topic: Clipping area issue for cladding  (Read 270 times)
spomenik
« on: December 19, 2025, 12:20:14 am »
When applying a cladding preset to a new spline, it has hilariously applied itself to almost the complete inverse of where it should be. I was wondering if the suggestions in the official YT video on cladding might help, in the Expand Hierarchy section, but so far no.
The spline came from using the Create Shape from Edges function on layer CH-EXT-LapSiding-7IN_Lap Siding - 7", so I'm not sure if it might just be a generic issue with the spline to begin with.
Re: Clipping area issue for cladding
« Reply #1 on: December 19, 2025, 08:16:08 am »
I’d recommend checking whether these splines are closed and, if so, adjusting their Material IDs. If you’re still experiencing issues, please feel free to send us your scene, ideally simplified and containing only the problematic object(s), and we'll check it here. Thank you in advance.
spomenik
« Reply #2 on: December 19, 2025, 11:02:11 pm »
I believe that was essentially it - the imported geometry produced a problematic spline when I tried to automate the process. I'm new to both RailClone and Revit files, so I appreciate the patience through my stupid questions!
