Author Topic: How to manage this?  (Read 25358 times)
Tom_1028
How to manage this?
« on: September 12, 2025, 10:14:25 am »
Hi everyone,
Here is an annoying problem I face recurrently when dealing with footpaths and curbs (see the screenshot attached).
How do you manage to get neat intersections?
Thank you in advance for the help,
Re: How to manage this?
« Reply #1 on: September 12, 2025, 11:03:20 am »
Hi Tom,
I'm sorry to hear that you're facing these troubles. As mentioned in these closely related forum threads http://forum.itoosoft.com/index.php?topic=1636.0 / http://forum.itoosoft.com/index.php?topic=1679.0:
"When RailClone is used to create pavements or curbs on closed corners, it is frequent to encounter overlapping issues because the geometry intersects with itself. Unfortunately, when this happens, there is not an easy way to fix it. However, there are several techniques that would help us to avoid overlapping:
  • First, increase the spline's interpolation using Style > Curve Steps (i.e., with a value of 100).
  • If the path turns in both directions, we can minimize the issue of centering the segments on the Y-axis in relation to the spline. To achieve this, set each segment's "Y Alignment" to "Center" within the Style Editor.
  • Since the decisive value in this problem is the corner's radius, it may be useful to adjust it dynamically. RailClone allows creating rounded corners automatically by setting the parameter Rules > Corner > Fillet Radius in the Generator. This way, we can visually check at what radius value the overlapping problem starts.
  • Sometimes it may be necessary to refine the segment's geometry so that it bends better on curved paths. To do this, select the segment in the Style Editor and click "Extract Segment" in the toolbar. A new object will be added to the scene; simply select and refine it (e.g. by applying a Tesselate modifier).
When the curve is so close that none of these techniques works, the only way may be to use mitered corners. This can be done by setting the generator Rules > Corner > Bevel Mode to a value other than "Disabled" (e.g. "Extend"). The Fillet Radius parameter must be zero."
I hope this helps.
Tom_1028
« Reply #2 on: September 12, 2025, 11:12:35 am »
That surely helps.
Thanks a lot.
