Author Topic: How to retain vertical deformation without x spline  (Read 2586 times)
Jason
« on: March 30, 2022, 04:43:15 am »
Hi There,
Does anyone know how to retain vertical deformation without using a X Spline,
I understand the traditional method is to use a X spline and pull up the Z axis with vertical Deformations in L1s to achieve it, but i have multiple things i want to join in multiple L1s and trying to simplify the procedure.
Trying to just key in height diffrences from start to end and have a vertical deform.
Re: How to retain vertical deformation without x spline
« Reply #1 on: March 30, 2022, 09:49:59 am »
I'm afraid at present that isn't possible, as you've pointed out the deform modes expect a spline. I'll pass the suggestion on to the team though.
