Author Topic: Something changed about the way RC recognizes surfaces?  (Read 2438 times)
IT1371
« on: October 26, 2022, 03:08:04 pm »
I've been using this feature to drop RC geometry to surfaces forever. It's been working great for many years and now, in the simplest project I can imagine, it pretty much makes scrambled eggs.
The objective is simple - have those 60cm planes lay flat on top of the pavement geometry. Previously I used it via the evenly rule, but now I just assign it to markers instead.
3ds max file attached.
I tried adding retopology or subdivides to the pavement object but it makes no difference.
Same goes for the segment I want distributed...
How can I fix that?
Re: Something changed about the way RC recognizes surfaces?
« Reply #1 on: October 27, 2022, 11:20:03 am »
Well, the “rcline” spline is right on the edge of the “pavement” object used as a Surface in the RailClone object. Making the surface slightly larger (for example by using the Edit Polygons > Outline & Inset tools) is good practice to avoid any unwanted deformations. In this case, increasing the Y Offset parameter slightly seems to fix it also.
Please find attached the modified scene (221027_sample_iToo.max).
