Toggle navigation
Login
Register
RailClone
RailClone Pro (*)
start and end spline offset - how to?
« previous
next »
Print
Pages: [
1
Author
Topic: start and end spline offset - how to? (Read 8630 times)
harumscarum
Full Member
on:
September 09, 2014, 08:04:23 pm »
i wonder if it possible to make offset from start and end of spline and keep adaptive evenly mode like on image below
would be enough if it will be just global value for both start and end offset
Logged
harumscarum
Full Member
Re: start and end spline offset - how to?
Reply #1 on:
September 10, 2014, 09:24:18 am »
seems it is rather feature request than "how to"
would be great to have option to set offset from start and end of spline
Logged
Administrator
Hero Member
Reply #2 on:
September 10, 2014, 12:34:35 pm »
I'm afraid it's not possible, because Evenly partition is done using the full length of the spline.
The only way would be using
Base Objects->Start/Lenght
, but probably that is not what you need, because it uses absolute spline positions.
Logged
harumscarum
Full Member
Reply #3 on:
September 10, 2014, 12:51:55 pm »
i see.
tried padding of start/end segments, but it not working with Evenly mode.
so may be it is possible to add Offset value for start and end segments so it will subtract from spline length?
Logged
Administrator
Hero Member
Reply #4 on:
September 10, 2014, 01:03:38 pm »
No, Start/End Segments are not taken into account for the Evenly partition. That process is done before evaluating the nodes.
This feature requires a specific implementation. We have some ideas in the wishlist that may work for this.
Logged
harumscarum
Full Member
Reply #5 on:
December 24, 2014, 05:39:52 pm »
Thank you very much for this feature i found in latest builds!
two more requests:
1. is it possible to make it support negative offset?
2. apply start/end offsets after Y offset for correct corners
Last Edit: December 25, 2014, 12:12:04 am by harumscarum
Logged
Administrator
Hero Member
Reply #6 on:
December 26, 2014, 10:46:43 am »
1. I think negative offsets may be a problem, because it would be necessary to "extend" the spline, but we'll take a look to it.
2. I just noticed that Y Offset modifies the spline's end (we'll fix that). But what is the problem with the corner ? I don't understand...
Logged
harumscarum
Full Member
Reply #7 on:
December 26, 2014, 03:31:03 pm »
2. i put an answer in more relevant thread -
http://forum.itoosoft.com/index.php?topic=2661.0
thanks
Logged
Print
Pages: [
1
« previous
next »
RailClone
RailClone Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
