Author Topic: StyleEditor suggestions  (Read 23660 times)
OB
Re: StyleEditor suggestions
« Reply #30 on: September 11, 2014, 04:01:48 pm »
Yeah similar to this one , but with addon of the auto-wiring function , for example you have a segment and a random node , you just take wire of the segment and put it on top of the random node , without worrying to target that green circle :) Sometimes its a bit annoying to place a wire in it exactly , when you are zoomed out for example.
« Reply #31 on: September 11, 2014, 04:16:48 pm »
I hate then this happens:
« Reply #32 on: September 11, 2014, 06:50:06 pm »
Yes, we must tweak a bit the wiring areas, including a default slot so links can be dropped directly over a node.
« Reply #33 on: November 16, 2014, 10:57:49 am »
Another style editor suggestion:
Rightclicking any node should select it and then do rightclick action.
Now it just performs rightclick action on previously selected(or not) node.
harumscarum
    • harumscarum's portfolio
« Reply #34 on: November 16, 2014, 11:26:24 am »
i'm afraid it is not possible due to this issue - http://forum.itoosoft.com/index.php?topic=1926.msg7122#msg7122
but i have another relevant suggestion - automatically show and expand Export menu when drag to connect any Parameter and Arithmetic node
« Last Edit: November 17, 2014, 06:16:27 pm by harumscarum »
