Author Topic: Railclone Panel Tutorial Materials - Newbie question  (Read 3688 times)
KB2072
« on: May 13, 2017, 04:19:52 pm »
I am having issues getting the materials to work to complete the tutorial. I believe I have everything properly pathed,  though I could use some guidance  to determine where I should look to solve this problem of mapping.
As you can see, the original railclone components are not rendering correctly prior to incorporation into the railclone object, nor do they properly show on the completed Railclone project.
Vray 3.50.04, Max 19 SF
« Last Edit: May 15, 2017, 10:14:54 am by Paul Roberts »
KB2072
Re: Railclone Panel Tutorial Materials - Newbie question
« Reply #1 on: May 13, 2017, 04:22:16 pm »
missed one attachment.
« Reply #2 on: May 15, 2017, 11:21:12 am »
Hi, Thanks for contacying us.
The RailClone object does not automatically adopt the materials  applied to the source segments, so you must do this manually. Just pick the same material that's on the geometry and apply it to the RailClone object. This tutorial also uses Automatic Box mapping to add UVW mapping for the panels, so you will see a difference between the original segments and the final object.
This is the final step in the tutorial.
Many thanks,
