Author Topic: Several Marker Data problems  (Read 2643 times)
« on: March 07, 2022, 05:15:15 pm »
I created two generators for parallel comparison:
The L1S sets segments at the Start and the A2S sets segments at the End.
A2S is not set on extended X/Y but uses Y-size mode (adding Y spline will not make any difference).
1. A2S use only the first Marker (I thought it was bound only when used Extended X/Y mode).
2. Filtering on MatID returns wrong results when used on the Generator but works as expected when Conditional is used. (I`ve exposed Constant Nodes for the test)
« Last Edit: March 08, 2022, 08:30:02 am by Dragan »
Re: Several Marker Data problems
« Reply #1 on: March 08, 2022, 12:27:42 pm »
Hello Dragan,
Thanks for the report. I can reproduce them both in your file so I've logged it as a bug and passed it over to the development team.
Cheers,
