Author Topic: Railclone + Deadline Texturing issue  (Read 2494 times)
dominic_patel
« on: August 29, 2019, 10:25:22 am »
Hi all,
I have an issue where one node in our network is not picking up the textures from the installed packages when rendering via thinkbox deadline.
We have used the registry fix as per the post on the forum so that all nodes are looking to the server for the assets. All other nodes seem to be working as expected. The node renders textures from Forest pack which are located on the same drive.
Is anyone able to advise as to what might be causing this issue
« Last Edit: August 29, 2019, 10:27:06 am by dominic_patel »
Re: Railclone + Deadline Texturing issue
« Reply #1 on: August 29, 2019, 12:14:11 pm »
Sounds like an issue with that node. Since every other nodes work, might it be You did something differently on that node?
Please reinstall the plugin on that node. Make max is closed and relevant services are not locking the files from overwriting.
