Author Topic: Vray Enmesh Modifier & RC  (Read 4157 times)
Terri Brown
    • Terri Brown 3D
« on: August 03, 2023, 04:09:54 pm »
Hi guys. I have created a wicker parasol using the vray enmesh modifier (see attached). However, when I distribute it using RC the enmesh modifier doesn't show. I have attached the parasol as a group Is it not compatible with RC?
Re: Vray Enmesh Modifier & RC
« Reply #1 on: August 03, 2023, 04:12:35 pm »
Hello Terri,
In all honesty I've not yet tested RailClone with EnMesh fully myself, but I'd imagine that it has similar restrictions to Displacement modifiers which also do not work with RailClone. Your best bet is probably to instantiate that object using RailClone Tools.
I hope that helps,
Terri Brown
    • Terri Brown 3D
« Reply #2 on: August 07, 2023, 10:21:21 am »
Hi Paul,
Thanks for that. Please see the results after instantiating...
Suggestions?
« Reply #3 on: August 07, 2023, 10:58:25 am »
I've done some basic tests here and instantiating with RailClone tools did seem to work. If you haven't already, could you make sure that Bend and Slice are turned off for the segments in RailClone to ensure that they are instances and not collapsed to a mesh.
Many thanks,
Terri Brown
    • Terri Brown 3D
« Reply #4 on: August 07, 2023, 04:15:20 pm »
yes, bend & slice were already turned off
« Reply #5 on: August 07, 2023, 04:25:06 pm »
That's strange then. Perhaps you can send us the simplified scene to email? Then I can take a closer look and see if I can identify a cause.
Many thanks,
Paul.
Terri Brown
    • Terri Brown 3D
« Reply #6 on: August 07, 2023, 04:50:25 pm »
ok sure. will do
Terri Brown
    • Terri Brown 3D
« Reply #7 on: August 08, 2023, 10:17:45 am »
Hi Paul,
So when I imported the RC object into a new scene, it all worked as expected. So I deleted and reassigned the enmesh modifier in my existing scene and it's working now.
Thank you!
