RailClone => RailClone Pro (*) => Topic started by: Alex.S on December 16, 2016, 11:15:08 am
Title: Inconsistencies with XSplineMatID?
Post by: Alex.S on December 16, 2016, 11:15:08 am
I've been having some inconsistencies with XSplineMatID, in the most recent build.
I want to change my end segment type based on the Spline Mat ID.
If the Spline Mat ID was between 3 and 10 (so 4,5,6,7,8 or 9) I wanted a to select a different end type. If I create a arithmetic node and use a selector this does not work correctly. It sees the ID of the last default segment instead.
I am able to get it to work ok with nested conditional statements though. I was just wondering about the arithmetic not working though as obviously it's possible to do much more powerful things there.
Title: Re: Inconsistencies with XSplineMatID?
Post by: Michal Karmazín on December 16, 2016, 11:43:17 am
Upon my quick test, the Arithmetic Operator's XSplineMatID variable seems to give correct values for the Selector Operator used to pick the End Segment. Would you mind to describe your set-up more in detail (a minimal scene, where you can reproduce these troubles would be ideal).
Post by: Alex.S on December 16, 2016, 12:07:26 pm
I think you need to have a default segment. I'll do a quick test.
Post by: Alex.S on December 16, 2016, 12:22:02 pm
Can't reproduce now, I'll just put it down to me doing something really stupid, sorry for wasting your time.  :o
Post by: Michal Karmazín on December 16, 2016, 12:35:20 pm
No worries at all. If the issue reappear, please let us know.
