Author Topic: Railclone bug in last version 616  (Read 4778 times)
ben_img
« on: February 22, 2024, 11:13:08 am »
we updated to the latest version, to see an error that wasn't there before
(previous version tested 522 was working fine)
now 616 the evenly mesh is going through the top
(max file attached)
Re: Railclone bug in last version 616
« Reply #1 on: February 22, 2024, 11:25:51 am »
In RailClone 6.1.5, we have fixed an older bug that caused the Generator's 'Flatten Stepped' function to have no effect. To "fix" your scene, you can simply deselect the mentioned feature. Please find attached the modified scene (240222_testRC_iToo.max).
ben_img
« Reply #2 on: February 22, 2024, 11:42:06 am »
thank you for your quick response.
noted for the "flatten stepped" thanks
« Reply #3 on: February 22, 2024, 12:09:41 pm »
In this specific case, problem is caused because there are two generators, and the spline is "flattened" in different ways, since that depends of the segments used in each generator.
In the attached image you can see in purple color the flattened spline for each generator (these splines are created internally, and are not visible for the user).
« Last Edit: February 22, 2024, 12:11:14 pm by iToo »
