RailClone => RailClone Pro (*) => Topic started by: Ken Turner on May 09, 2018, 10:38:38 pm
Title: Inner corner issues
Post by: Ken Turner on May 09, 2018, 10:38:38 pm
I'm using railclone 3.0.9
I'm trying to build a tower block generator using a closed spline and an A2S gernerator
I'm having real issues with the corners especially when I try add top and bottom sections.
Its even worse with y-evenly machine floors which just seem to break the corners completely.
I've got multiple attempts included in the attached  max file. If anyone has a solution that would be much appreciated
many thanks in advance
Title: Re: Inner corner issues
Post by: Rokas on May 10, 2018, 11:43:49 am
Hi, Welcome to the forum
(https://i.imgur.com/MWv8DdT.jpg)
I attached my modified scene with some fixes. Hope that helped. If there is anything else You need help, let us know
Post by: Ken Turner on May 10, 2018, 01:44:59 pm
Hi Rokas, thanks for your help
What version of max and rail clone are you using ?  I'm on max 2018 and I just upgraded to railclone 3.1.0
When I open the file you sent it doesn't look like your image and i get an error message :-
'Incompatible railClone object found please upgrade to the latest version'
Are you using the Beta ?
-k
Post by: Rokas on May 10, 2018, 02:05:39 pm
Ah yes, I use beta. Does it open for You apart that error?
Post by: Ken Turner on May 10, 2018, 02:15:54 pm
yes the file opens but it looks wrong (not like your image )
are you on max 2018 ?
Post by: Rokas on May 10, 2018, 03:34:55 pm
There are improvements which affects Your styles in beta releases. Will You beta ?
Post by: Ken Turner on May 10, 2018, 05:16:13 pm
just upgraded to the beta.
Good to see your solutions.
it almost works now. The only thing I'd like to fix is getting the tiles to be complete in adaptive mode when using corners.
without corners everything lines up and I don't get partial tiles.
when I add corners the tiles don't stretch properly and i get partial tiles . I'll upload an example later today
