Toggle navigation
Login
Register
RailClone
RailClone Pro (*)
Inside Corner Sidewalk
« previous
next »
Print
Pages: [
1
Author
Topic: Inside Corner Sidewalk (Read 5817 times)
Bobby Parker
Sr. Member
on:
September 18, 2017, 06:34:01 pm »
I would think that this is a very comment scenario, however, it obviously isn't correct.
Logged
Bobby Parker
Sr. Member
Re: Inside Corner Sidewalk
Reply #1 on:
September 18, 2017, 11:47:14 pm »
I ended up going with a radius, however, I am still getting overlaps. The radius is rather large, too. Also, having a railclone anything in my scene makes my scene very slow. 3DS MAX 2018 with all updates and the latest Railclone.
Last Edit: September 19, 2017, 03:33:52 am by UC3472
Logged
Bobby Parker
Sr. Member
Reply #2 on:
September 19, 2017, 03:03:52 pm »
I ended up using tried and true sweeps, which took a couple minutes. I spent the whole day trying to get it to work with Railclone. I am finding anything but a straight run doesn't make much sense.
Logged
TL1895
Sr. Member
Reply #3 on:
September 20, 2017, 05:02:10 am »
For the same reasons, I too, avoid the RC for sidewalks and roads 9 out of 10 cases. Hope it will improve
Logged
ITOOSOFT
Hero Member
Reply #4 on:
September 20, 2017, 11:23:11 am »
Thanks for the feedback guys. You're right that the pavement styles don't work well with hard corners. In part this is because adaptive mode which is used in these styles does not allow for bevelled corners. You can enable bevelled corners by changing the default mode in the generators to Tile
This will slice the pavers at the corner. Unfortunately this isn't really how pavements are built in real life. We'll take a look at these styles to see what can be done, and we're also going to take another look at enabling corner bevel when using adaptive mode. If the depth of the pavements was fixed this would be a lot easier - would fixed width pavements be useful for your work?
Many thanks again,
Logged
Print
Pages: [
1
« previous
next »
RailClone
RailClone Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
