Author Topic: Irregular stone wall  (Read 5768 times)
iCreateLtd
« on: December 06, 2023, 06:24:52 pm »
Hi all
I need to make this to go on an external wall of a building.  I've found textures that are quite similar but I then saw this video:
https://www.itoosoft.com/tutorials/stone-walls-and-floors-with-railclone?back=page%3Dall%26search%3Dstone
Does anyone know if the scene files exist for this as I'm on quite a tight deadline ?
I also need to have them with varying heights.  Can anyone see this being a problem using Railclone?
« Last Edit: December 06, 2023, 09:41:18 pm by iCreateLtd »
Re: Irregular stone wall
« Reply #1 on: December 07, 2023, 11:59:07 am »
The mentioned tutorial was done by Adán Martín (3dcollective.es). I don't think that the scene is publicly available, but by using the mentioned workflow (for the Displace modifier, he is using a texture from https://www.textures.com/), you should be able to prepare your own version relatively quickly.
