Author Topic: Issues with Railclone flooring layout  (Read 14150 times)
Theo
« on: November 01, 2024, 11:36:10 am »
Hi, I'm currently having an issue with my RC setup.
I am trying to distribute some 'planks' along a curved spline so that the flooring follows the angle of a room, however - I can't get the planks to stagger in the direction I need; I can get the randomisation in the other direction, but I can't seem to rotate the RC succesfully.
My Current Setup: (See screenshots attached included for better idea)
Full Plank mesh (Box A)
Half Plank mesh (half length of Box A)
Curved Spline (For distribution)
Clipping Area to retain shape of room
Array 2s1 Generator
Theo
Re: Issues with Railclone flooring layout
« Reply #1 on: November 01, 2024, 12:12:53 pm »
Hi Theo,
You don’t need to use the Conditional Operator - connecting the Sequence Operator to the Start Input of the Array 2S1 and using only the Long Plank Segment for the Default Input should do the trick.
Hi Michal,
Thank you for the prompt response.
I have tested this and unfortunately it isn't working as intended yet.
Please see attached image of how I need it to look and the updated RC window after the changes you suggested
« Reply #2 on: November 01, 2024, 12:22:00 pm »
Hi Theo,
You might find it helpful to use 'nested Generators' for this. I've attached a sample scene of the proposed style setup. I hope you find it helpful.
Theo
« Reply #3 on: November 01, 2024, 12:47:24 pm »
Hi Theo,
Hi Michal,
This worked, thank you very much for sharing!
