RailClone => RailClone Pro (*) => Topic started by: IVORM on May 12, 2020, 05:53:23 pm
Hi all,
I would like to use a simple running bond for my street bricks (cobblestone) using a spline clipping area.
There are some complex video online which explains everything in detail, but I would like to use it just like the herringbone macro.
Any suggestions?
Simplest solution is to use Grid2 Image pattern and adjust units in non uniform fashion according to Your brick dimensions:
(https://i.imgur.com/32RJlRh.png)
Hope this helps.
Have posted in the wrong section. I need a solution for Railclone.
Sorry Rokas, for your time and effort. Should I move my question to the Railclone section?
In that case I attach You a running bond padding macro. Hope it works for what You want.
(https://i.imgur.com/0F65H7D.png)
Thank you very much Rokas!
