Author Topic: placing trees in the basin of walkways  (Read 2671 times)
Caypiranha
« on: March 28, 2023, 01:30:19 am »
Hi Guys,
there are some types of Basin for Trees on the Walkwaypresets.
But how do I place the trees precisely inside?  Is there a node I can use on the setup for the Walkways?
thank you in advance!
Re: placing trees in the basin of walkways
« Reply #1 on: March 28, 2023, 09:50:18 am »
Though the Forest distribution can be limited to a specific Material ID (in this case of basins), the recommendable workflow would be by using the Path Distribution Mode and adjusting the Spacing and Spline Offset values as needed. Optionally, you can use a technique explained in the Parking Cars tutorial - using markers created by RailClone.
Caypiranha
« Reply #2 on: March 28, 2023, 10:48:29 am »
I see. I´ll check it out - thanks! =)
