Toggle navigation
Login
Register
RailClone
RailClone Pro (*)
Offset for animated tank tracks?
« previous
next »
Print
Pages: [
1
Author
Topic: Offset for animated tank tracks? (Read 2648 times)
superrune
Newbie
on:
October 26, 2021, 02:53:30 pm »
Hi!
I am trying to make animated tank tracks in Railclone. I get perfect distribution across a spline, but I'm not sure how to animate the tracks. Is there a way to offset the entire railclone system along a looped spline?
Thanks!!
Logged
ITOOSOFT
Hero Member
Re: Offset for animated tank tracks?
Reply #1 on:
October 26, 2021, 03:18:25 pm »
If you don't mind a little bit of deformation then you can do this by animating the segment's X Translation value. Check out the attached file for an example.
Best,
Logged
superrune
Newbie
Reply #2 on:
October 27, 2021, 04:56:39 pm »
I would prefer no deformations, since the tracks will be very close to the camera in some instances
Looking in some older threads, I found I could animate the bevel offset to shift the entire track one segment. It doesn't seem to work with in-camera motion blur which is a slight issue. Do you have a wishlist tracker somewhere?
Logged
ITOOSOFT
Hero Member
Reply #3 on:
October 28, 2021, 01:31:26 pm »
Bevel Offset is good solution. Motion blur is an issue though as you pointed out. There are technical reasons why motion blur doesn't work. I'll pass it on to the development team, but I'm not sure that it could be fixed.
Logged
superrune
Newbie
Reply #4 on:
October 29, 2021, 08:07:10 am »
Thanks!
There really isn't any good solution for tank tracks in 3ds Max AFAIK, unless you go for complex rigging solutions. They tend to be pretty slow unfortunately. If there could be a solution from Railclone, animators doing tanks, bicycles and other animating chains would be really happy
Logged
Print
Pages: [
1
« previous
next »
RailClone
RailClone Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
