Author Topic: Railclone define Seed of Randomize Operator  (Read 2668 times)
link3d
« on: August 16, 2022, 01:14:23 pm »
I have the following problem:
I'm trying to use the same ranomize seed multiple times, but even if I use the same Randomize instance in two Railclone Generators the results are different.
Is there a way to define a randomize seed?
Best regards
Re: Railclone define Seed of Randomize Operator
« Reply #1 on: August 16, 2022, 01:28:39 pm »
You can probably use the Sync Between Generators option and use the same Random node between both generators. Note however that generator types can't be mixed, so a random number node wired to an L1S and an A2S will get different results, but an L1s and L1s or A2S and A2S will get the same.
link3d
« Reply #2 on: August 16, 2022, 01:58:16 pm »
Hi thanks for the reply.
The sync between generators option is only available on a random parameter node. The randomize operator node I'm using does not have  any customization in that regard.
Is there a way to randomize Segments with the random parameter?
« Reply #3 on: August 16, 2022, 02:07:10 pm »
Hi, Yes you can wire it to the Index input of a Selector operator. That will then basically act as a Randomise operator but with a lot more control.
Cheers,
