Author Topic: Slopped sideway  (Read 2593 times)
Ignacio
Slopped sideway
« on: February 25, 2022, 08:46:23 am »
Hello all,
I am having some problems with a dropped area of the sideway.
By default there is this kind of special anti slippery pavement. I am trying to have the same pavement as the street on this sloped area since this will be a car entrance, but every time I switch the nodes and try new things I get weird results.
Any help would be much appreciated.
Thank you
Ignacio
« Last Edit: February 25, 2022, 08:55:50 am by Ignacio »
Re: Slopped sideway
« Reply #1 on: February 25, 2022, 01:50:39 pm »
You won't be able to just switch that geometry for the existing standard paving because those drop-kerb pieces have been modelled with the ramps etc as part of the geometry. Instead, you'd need to model equivalent paving slabs use them to replace those already in the graph. Our latest tutorial explains a bit on how to extract geometry and either adapt or replace it. You can watch it here: https://www.youtube.com/watch?v=sT1wK5-AovE
