Author Topic: Limit Y axis height to a count.  (Read 3139 times)
Anthony Lester
« on: August 01, 2019, 06:06:42 pm »
Very quick question I hope. I am sure I missing a very simple trick here. What is the easiest way to limit the y height of an array to a count. for example if I had a brick wall and I wanted to limit the height to 4 bricks high (or 4 rows) instead of stipulating a height in scene units or with a  spline.
TIA
Anthony
Re: Limit Y axis height to a count.
« Reply #1 on: August 02, 2019, 07:08:59 am »
for this You need to export Generators Y Size parameter.
And export Bricks Y Size Attribute.
Then multiply Brick Size by the number of bricks You want and plug that to Generators Y size.
Illustration:
Anthony Lester
« Reply #2 on: August 05, 2019, 09:54:31 am »
Thanks, unfortunately in this instance this approach didn't work as I have a random scale transform on the y in order to produce a dry stone wall effect. What I ended up doing was simply switching off slice.
Thanks again
