Author Topic: RailClone Pivot  (Read 14074 times)
BV6856
RailClone Pivot
« on: September 02, 2024, 11:30:05 am »
Hello, developers. I have a question, I made a door that changes its parameters: height, width, thickness. I also made a rotation, but I can not make the rotation on the hinge mount. How to make it so that the opening was on the hinge of the mount?
1 position = 0 degrees
2 position = 45 degrees
3 position = 90 degrees
Re: RailClone Pivot
« Reply #1 on: September 02, 2024, 11:54:16 am »
You can adjust the Pivot Point as needed - if it's already an RC object, you can 'nest' it within another RC object and use the Pivot Alignment for that Segment. I hope that helps,
