Author Topic: Limits Padding does not accept the result of a logical operation  (Read 8403 times)
Limits Padding does not accept the result if some Conditional (If) Function is involved.
Re: Limits Padding does not accept the result of a logical operation
« Reply #1 on: May 06, 2024, 08:58:56 am »
Hi Dragan,
I've just done a quick test (please find attached a sample scene 240506_LimitsPaddingConditional_SampleScene_iToo.max) and in my style setup it seems to work just fine. Would you mind sending us / uploading your scene (ideally simplified and containing just this problematic object(s))? Thanks in advance.
« Reply #2 on: May 06, 2024, 11:06:32 am »
Limit paddings are often broken when Marker Data is involved except in Free Mode but this is for another topic and another example..
note: I have found a workaround for the problem so, please don`t waste your time finding one (using multiple generators with different ID limits and padding settings), but for more complex graph this is an issue.
Thank You.
« Last Edit: May 06, 2024, 11:12:20 am by Dragan »
« Reply #3 on: May 06, 2024, 11:45:49 am »
Big thanks for the provided scene. It'll be investigated by our main developers. Once again, BIG thanks for your feedback.
