RailClone => RailClone Pro (*) => Topic started by: Dragan on May 04, 2024, 12:09:33 pm
Title: Limits Padding does not accept the result of a logical operation
Post by: Dragan on May 04, 2024, 12:09:33 pm
Limits Padding does not accept the result if some Conditional (If) Function is involved.
Title: Re: Limits Padding does not accept the result of a logical operation
Post by: Michal Karmazín on May 06, 2024, 08:58:56 am
Hi Dragan,
I've just done a quick test (please find attached a sample scene 240506_LimitsPaddingConditional_SampleScene_iToo.max) and in my style setup it seems to work just fine. Would you mind sending us (https://forum.itoosoft.com/faq/how-to-send-a-file-to-itoo-software/) / uploading your scene (ideally simplified and containing just this problematic object(s))? Thanks in advance.
Post by: Dragan on May 06, 2024, 11:06:32 am
Limit paddings are often broken when Marker Data is involved except in Free Mode but this is for another topic and another example..
note: I have found a workaround for the problem so, please don`t waste your time finding one (using multiple generators with different ID limits and padding settings), but for more complex graph this is an issue.
Thank You.
Post by: Michal Karmazín on May 06, 2024, 11:45:49 am
Big thanks for the provided scene. It'll be investigated by our main developers. Once again, BIG thanks for your feedback.
