Author Topic: tiles alignment - how to do it ? is it possible ?  (Read 8302 times)
FJ7201
« on: January 17, 2017, 12:03:02 pm »
Hi , i want to do floor tiles and and wall socet tiles , same size to fits joints on both . First i try to do it by one 2s array add segments on sides and corners and it works perfectly in case simple shapes, but in more complicated  fg L shape don't. So i try to do it by two arrays floor by 2s and wall socet by 1s it works better but i dont have any idea ho to fits joints, i attached screen to show what i mean , any sugestion most welcome .
Re: tiles alignment - how to do it ? is it possible ?
« Reply #1 on: January 17, 2017, 04:06:02 pm »
Because of the way, how the array is constructed when using the Extend X/Y Size to Area feature, it's tricky to get Segments on "clipped borders" aligned with such array. An option might be to use X & Y Splines (or X & Y Size as on attached sample scene) instead to build these using additional Generators. Hope that helps a bit.
Best regadrs,
HU0164
« Reply #2 on: May 06, 2024, 11:42:47 am »
Hi, I'm having the same problem.
Is there a more recent procedure for obtaining this result?
