Author Topic: parameterising window  (Read 8165 times)
M55
Re: parameterising window
« Reply #15 on: July 02, 2018, 02:09:30 pm »
... now it works fine ... forgot about that change  8)
RL1396
« Reply #16 on: July 02, 2018, 10:29:21 pm »
YES.
That's the good solution. Thank you.
M55
« Reply #17 on: July 05, 2018, 10:25:06 am »
just tried to build a new window based on the tutorials.
Now i have two questions
- is the second frame on the bottom intended ... and is it possible to get rid of it. in the video everything looks fine on the bottom.
- what are the two parameters for ... the panel height 2 works fine but the pane height 1
OK found the answer in the "parameterising blinds tutorial" pane (panel) height 1 is for the metal blinds on bottom ... they are missing in the parameterising tutorial files .. thats why there is an "empty" frame on the bottom
« Last Edit: July 06, 2018, 07:44:24 am by M55 »
